virtual templete in FR
Hi, I have configured Virtual-Templete over PPP on Frame Relay connectivity. THe problem is, whenever I am configuring EIGRP or OSPF. Then Neighbor is established, but it is not advertising the Routes/Network......
Hall of Fame Super Silver
Re: virtual templete in FR
Hello Rupesh,
check the ospf network type on both sides
using
sh ip ospf int multilink XX
a network type mismatch can cause this problem.
the command ip ospf network can be used in interface configuration mode to fix this.
Hope to help
Giuseppe
Blue
Perhaps you can post the configs.
Hi, I am facing the same problem in RIP and EIGRP. Please help.
One thing common with RIP and EIGRP is split horizon.
I have disabled the Split horizon. This problem is with all the protocols. Please help. This is only happening with
113
