Vlan 3524
Dear All,
I have 3524 switch with ver 12.
I want to add 3 vlans , when I do no shut on vlan interface, it still shows me shutdown in running config.
So please any one can help me to bring that particular vlan up.
Rgds,
JItesh
Silver
Re: Vlan 3524
Hi Jithesh,
From what it looks like you are trying to add SVI interfaces
int vlan 1
ip address x.x.x.x Y.y.y.y
int vlan 2
ip address z.z.z.z y.y.y.y
This is not possible since 3524XL switch is a Layer 2 switch. The SVI interfaces are supposed to be used for management purposes only.
So this means you can't have two interfaces up at the same time.
Cheers
Hoogen
Re: Vlan 3524
Hello Hoogen,
Thanks for reply. So is there any way to create multiple network on 3524.
Rgds,
Jitesh
Silver
Re: Vlan 3524
Well you need to have a L3 switch\Router to which you can connect this 3524 too and have multiple networks. 3524 being a L2 switch cannot do inter vlan routing. Only L2 seggregation is possible.
Hoogen
Do rate if I have helped you out.
134
