06-14-2012 04:03 PM - edited 03-04-2019 04:41 PM
Dear sir
We are an ISP we have LNS cisco router the topology :
Backhule Fiper link from service provider
internet fiper from service provider
LNS
internet router with B
Posted by WebUser Nizar Hamoudah from Cisco Support Community App
06-14-2012 11:16 PM
Hi Just create vlans like this:
config t
interface Vlan1
description *** gfdgfgdgd ***
ip address xxx.xxx.xxx.xxx 255.255.255.0
no shut
interface Vlan2
description *** xyz to ***
interface Vlan4
interface Vlan6
and assign to interface like this:
config t
interface fa0/0
switchport access vlan 1
no shut
interface fa0/1
switchport access vlan 2
no shut
interface fa0/1/0
switchport access vlan 3
no shut
is this you need or something else?
please rate if it helps.
06-15-2012 10:24 AM
Thank you for intrests
No not this exactly
Our network cosists of :
Backhule Fiper link from service provider ( for customer dial in )
LNS ( Aggregation Router )
internet router with BGP
connection :
Backhule ( user side ) connected to the cisco 2960 switch on a Vlan 126 using SFP port ( filber single mode ) with 400 MB speed and the first LNS Cisco Router connected to the same Vlan 126 on the same switch using Cat6 copper cable .
Vlan 128 consist of 4 ports one of them SFP port
i want to know what is the best configuration for VLAN and SFP Port that connected to Backhule and the port on the switch that connected to Router and the port on the router that connected on the switch , because i have some intrubtion between customers and LNS while the connectivity is on between me and ISP and i have enough Bandwidth
and another question is what is the configuration for second port on the Vlan if i want to add another LNS on the same VLAN ????
