VLAN CONFIGURATION
esfandiarfard
Need help please. Have 5 Vlans on 2970 switch that is communicating with the 3750 L3 . On the 2970 I need to find out which PC/Computer is connected to lets say port 20 of the 2970. Since 2970 is a Layer 2 switch, how can I achieve my goal , I think MAC address is my answer but I need the IOS commands please. If you can think of some other utilities that would help I apperiaciate it very much. Thank you
Richard Burts
Saied
I doubt that you will accomplish this with a single command or by anything on a single box. But I think that you could accomplish it by doing this:
- on the 2970 do show mac-address which should show the layer 2 forwarding table (what is refered to as cam on some other Catalyst switches). Look for port 20 and note the MAC address.
- on the 3750 do show arp and look for the MAC address. This should give you the IP address of the device on port 20.
Rick
Rick
Rick's right, you will need to chase this on both devices. Try this
2970 - sh mac-address-table interface fastEthernet 0/20
This should provide you with the MAC address. Use this address on 3750 as follows
sh ip arp | include xxxx.xxxx.xxxx
You should see host's ip address.
Slav
Also, using the mac address, you can search the OIU listing at
http://standards.ieee.org/regauth/oui/index.shtml
to find the maker of the device.
