Community Member
VLAN Limitation on 7206 VXR
7200VxR(config-if)#vlan-range dot1q ?
<1-4094> First VLAN ID in range
Is this VLAN Limitation on 7206 VXR???
I need to have 4096!!!
Some info on this would definitely be rated :)
1 REPLY
Community Member
Re: VLAN Limitation on 7206 VXR
the 2 you cant use are reserved! DUH!
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a7c.html
besides, what are you going to do with 2 measily extra vlans?
108
