VLAN rate-limiting (Catalyst 3750)
Hi, I have following configuration
mls qos
class-map match-all cm-int-test
match input-interface FastEthernet1/0/23
policy-map port-test
class cm-int-test
police 256000 48000 exceed-action drop
policy-map vlan-test
class class-default
service-policy port-test
interface Vlan11
ip address x.x.x.x x.x.x.x
service-policy input vlan-test
switchport access vlan 11
switchport mode access
but the upstream traffic through the interface fa1/0/23 is still Full speed :(
Do you have any idea?
very thx
1 REPLY
Silver
Re: VLAN rate-limiting (Catalyst 3750)
I think you will need to add command "mls qos vlan-based". When applying policies on vlans , you will need to add "mls qos vlan-based" comamnd to the switchports so that they know where to get the policy from.
Following link may help you
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c8c4b.shtml
337
