Vlans on different Subnet mask in a Range IP
I've a problem in create subinterface Vlans a Cisco router. I want create subinterface vlans in a range ip (/24) with diffrent subnet mask.
I want create subnet mask /29 prior /27 (no order).
  1. 31.25.89.1/29
  2. 31.25.89.9/29
  3. 31.25.89.17/27
then create number 3 vlan (31.25.89.17), The error OverLap IP encountered.
how can solve this problem?
Everyone's tags (5)
Bronze
Dear Ehsan,
Thank you for reaching the Small Business Support Community.
What is the router model and firmware release version you are working with so that I can reproduce your scenario? I'll be looking forward to hear from you.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Dear Jeffrey,
the Router Model Cisco:
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
I can't change senario. I need to this senario.
Best Regards,
Bronze
Hello Ehsan,
The Cisco 2801 is not part of the Small Business routers and therefore I suggest you either to move this post from the "Action" panel on the top right corner to the LAN>Switching>Routing support forum or open up a new one.
I am sorry I can not be a better help but I am sure one of our community members of the enterprise (IOS based devices) forum is going to be able to provide you and accurate advice/solution for your inquiry.
Thank you for your time,
Re:Vlans on different Subnet mask in a Range IP
Hi Ehsan,
The reason for the error is that the third subnet will overlap with the first two. The third subnet is actually 31.25.89.0/27 with a range of 31.25.89.0-31.25.89.31.
If you want to use a /27, the next available subnet will be 31.25.89.32/27.
Hope this helps,
Mike
Sent from Cisco Technical Support Android App
672
