Community Member
Voice and data traffic
Dear all,
I have a voice over ip solution on my LAN,
I have some problem on my voice, So, I decided to create voice vlan,
any better solution?
Re: Voice and data traffic
Hi ,
IF you are using VOIP in a single LAN with a single switch then , a seperate VLAN would be fine . But if you have a good switch network with data also eating up lot of bandwidth , then it would be better to do some priority queues for Voice traffic.
Hope this helps
regards
vanesh k
you should prioritize the voice traffic by implemeting some QoS.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f36e.html
Narayan
Community Member
what was the problem you had with your voice traffic?
214
