Voice Controller-7200 router
we have a cisco router 7206VXR (NPE225) processor with VXC-2TE1+ Port adapter, 2 ports installed for
voice calls.
I can see the following configuration in the router. where is the DSP module inserted? is it inbuilt
with VXC-2TE1+ Port adapter or separately we need to install in the simm module in the router?
I can see only one DSPfarm1/0. why DSPfarm 1/1 is not showing ?
Suppose i replace the existing VXC-2TE1+ Port adapter should i change DSP configs as well?
dspint DSPfarm1/0
codec high ecan-extended
shut 0,6
controller E1 1/0
pri-group timeslots 1-16
controller E1 1/1
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 40000
isdn contiguous-bchan
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
isdn T310 60000
no cdp enable
voice-port 1/0:15
input gain 6
output attenuation -1
echo-cancel coverage 32
voice-port 1/1:15
input gain 7
output attenuation 3
echo-cancel coverage 24
echo-cancel mode 2
music-threshold -50
Re: Voice Controller-7200 router
Hi Shibu,
PA-VXC-2TE1+ comes with inbuilt DSPs. Its capable of supporting upto 120 calls.
Please refer to the Overview section in the following link -
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_white_paper09186a00800ae980.shtml
Not sure on the DSP farm question.
-> Sushil
Dear Sushil,
Thanks for the reply.
Please someone provide some more info regarding this.
107
