Voice VLAN not coming up
Hi guys,
I configured CME with QCT on a 2801. My network already has data vlans configured and a 3550 switch is being used for inter vlan routing. All access switches connect to the 3550. The CME router also connects directly to the 3550 with 2 subinterfaces(one for data and the other for voice). I created a voice VLAN interface on the 3550 switch but that interface never comes up on the 3550 switch(status = down / prot = down ) . Since the phones will connecting from the access switches, unless the voice vlan interface comes up on the 3550 they will not be able to reach CME router. I have doubled checked, shutting down and bringing the voice VLAN but it always stays down. Connectivity exist between the 3550 and CME router through the native vlan but, the voice subinterface is up on the CME router but voice VLAN interface remains down on the switch.
Thanks for coming to my rescue.
1 REPLY
Re: Voice VLAN not coming up
first i want to get more details about ur config and design
as i see from ur desicrition u have access switch conncted to L3 switch which 3550 then connected to CME
the question why u created voice vlan on the 3550?
it should be normal vlan with the same vlan id as the voive valn configured o n the access switch
let say on the access switch u have the folwoing
interface fa0/1
switchport mode access
switchport access vlan 10
voice vlan 20
spaning-tree portfast
nos hut
now the data vlan is vlan 10
voice vlan is 20
now the connection between the access switch with L3 switch 3550 must be a trunk
now on the 3550 u should have
interface vlan 10
ip address 10.1.1.1 255.255.255.0
ip helper address [cme vlan 10 ip]
no shut
interface vlan 20
ip address 20.1.1.1 255.255.255.0
ip helper-address [cme vlan 20 ip]
no shut
in the above config i put IPs just for this example and i assumed the DHCP config on the CME is configured
and because u do the vlan routing on the 3550 u have to put the vlan interface as a default gateway for each corsponding vlan
good luck
please, if helpful rate
315
