Voice Vlan
what are command required for voice and data traffic?
Case 1:
Let say voice is vlan 100 and data vlan 200.
Case 2:
Voice Vlan0 ( by using dot1p )and data will be native.
-V
Re: Voice Vlan
hi
case 1:
switch---IP Phone---PC
int f0/1
switchport access vlan 100
switchport trunk native vlan 100
switchport voice vlan 200
switchport trunk enc dot1q
switchport mode trunk
cdp enable
(option)
power inline auto
since voice vlan is taged, QoS for voice is needed.
Re: Voice Vlan
Check attached document,
Mohamed
Re: Voice Vlan
Here is attached file,
Its a sample config for 2970 Catalyst
Bronze
Re: Voice Vlan
On newer switches you don't have to switchport mode trunk.
The trunk is auto-negotiated.
All you need is:
switchport access vlan (vlan)
switchport voice vlan (vlan)
Nothing more, nothing less.
Re: Voice Vlan
thank you, Adam
our SW is old model. you are right.
regards
dongdong
328
