Webcast-Catalyst9k
vpdn enable on 1721
I'm getting my 1721 set up to connect via PPPOE and when I try to run the vpdn enable command I get this:
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip routing
Router(config)#ip subnet-zero
Router(config)#ip classless
Router(config)#end
Router#conf t
Router(config)#vpdn enable
% Invalid input detected at '^' marker.
Router(config)#
Is there a different command for this now?
TIA.
Jon
1 REPLY
VIP Purple
Re: vpdn enable on 1721
Hello Jon,
which IOS version are you running ? For VPDN, you need (with the IP Base feature pack) 12.3(16) -->
c1700-ipbase-mz.12.3-16.
Can you post the output of 'show version' ?
GP
425
