Webcast-Catalyst9k
VPDN tunnel doesn't work
I have got a LNS (cisco 7200) and I connect to a LAC.
The odd thing is that some users are connected with an IP address but they are experience with problem about opening determined web pages.
I can't understand why because they can send pings or traces.
Is there anything wrong in L2TP authentication?
Does anyone know anything?
Thanks.
Paolo
Re: VPDN tunnel doesn't work
Hi Paolo,
What AAA server do you use ?
Mohammed.
I resolved that issue but I have another problema.
Lot of our customers don't surf in the web but the vpdn session is working.
I don't understand what is the problem?
Thank you.
Best regards.
Paolo
Would you please paste the relevant config from the Routers please also a bit more detail about the matter.
Wilson Samuel
139
