11-05-2014 01:39 AM - edited 03-05-2019 12:06 AM
Hi Guys,
I'm wondering if you you can point me in the right direction. We have a requirement from the business to print labels from our as400 main frame via some of our partners sites. These are fairly small partners that tend to generally have a standard broadband connection with router connected. Their IT knowledge is limited and we are looking to implement a sort of plug play solution into the current infrastructure. So what we would like to is install ASA directly onto their LAN that has internet access but no public IP assigned and create effectively a VPN tunnel back to our ASA at HQ. I have a attached a quick drawing can you confirm if this is possible and the best way to achieve?
Solved! Go to Solution.
11-05-2014 04:52 PM
Yep this is possible. You can configure the 5505 to use ezvpn (vpnclient). Configure the group-policy to tunnel all traffic.
http://www.jump.net.uk/blog-cisco-easy-vpn-on-asa
11-06-2014 10:14 AM
That's great. Is the problem that you cannot ping just the LAN interface or can you not ping any host on the remote end at all?
You'll at least need to set the mode to "network-extension-mode". You might need firewall rules to allow the traffic. You also might need to set "management-access" to your inside interface.
11-05-2014 04:52 PM
11-06-2014 06:07 AM
Thanks for your assistance I've got it all up and running now. Just one final question now it's up and running the only thing I do not seem to be able to do is ping the LAN interface of the ASA on the remote end. I can see the firewall HQ sending packets but see anything in return and on the remote side I see nothing in the logs.
11-06-2014 10:14 AM
11-07-2014 04:00 AM
It was me, forgot to assign the management-access. Everything is working great. Thanks for your help.
11-07-2014 10:09 AM
Awesome
