Community Member
VPN between pix 515E v 7and router
I try to configure a vpn between a pix and router 1710, but i have some error message.
Error on pix:
QM FSM error (P2 struct &0x18893c0, mess id 0x79263e2d)!
[IKEv1] Removing
peer from correlator table failed, no match!
Show output:
BALIPIX001# show crypto ipsec sa
There are no ipsec sas
BALIPIX001# show crypto isakmp sa
There are no isakmp sas
Somebody have an idea. Any suggest 'll be appreciated.
Best regards.
1 REPLY
Community Member
Re: VPN between pix 515E v 7and router
Make sure that your isakmp policies match exactly on the router and PIX. For example you would receive that message if the router was using des encryption and the PIX was using 3des, or if any of the other policy parameters weren't matching.
hth
117
