VPN issues
Hi all,
I have configured one of our 828 router for PPTP VPN connection. I am comming across some strange issues.
The client gets connected and also obtains an IP address from the DHCP range which is assigned. Also by using "show user" command i can also see the list of connected users.
When the user pings an internal device, it ping initially for couple of times. Then nothing happens. From my end the same happens.
I cleared the virtual interface, and did a repetative ping. The ping goes for 10 and then........
Couldn't figure out what is the real issue. Can some one help me to fix the problem.
I verified the logs. I can see the following lines
2d21h: Vi3 PPP: Outbound cdp packet dropped, CDPCP state is Listen
2d21h: Vi4.4 PPP: Sending Acct Event[Down] id[5C]
2d21h: Vi4.4 PPP: Block vaccess from being freed [0x1D]
2d21h: Vi4.4 PPP: Missed link down notification
2d21h: Vi4.4 IPCP: Remove link info for cef entry 10.0.1.237
2d21h: Vi4.4 PPP: Unlocked by [0x4] Still Locked by [0x19]
2d21h: Vi4.4 IPCP: State is Closed
2d21h: Vi4.4 PPP: Unlocked by [0x10] Still Locked by [0x9]
2d21h: Vi4.4 PPP: Unlocked by [0x8] Still Locked by [0x1]
2d21h: Vi4.4 PPP: Phase is TERMINATING
2d21h: Vi4.4 LCP: State is Closed
2d21h: Vi4.4 PPP: Phase is DOWN
2d21h: Vi4.4 IPCP: Remove route to 10.0.1.237
2d21h: Vi4.4 PPP: Unlocked by [0x1] Still Locked by [0x0]
2d21h: Vi4.4 PPP: Free previously blocked vaccess
Rajesh
Re: VPN issues
The current IOS version which i am using is c828-y6-mz.123-6e.bin. Is there is any other version of IOS which will help to fix the issues.
I have attached the configs which i used for creating the PPTP tunnel.
ip dhcp excluded-address 10.0.1.0 10.0.1.255
ip dhcp excluded-address 10.1.0.0
ip dhcp pool local-POOL
network 10.0.0.0 255.0.0.0
default-router 10.0.1.2
netbios-node-type h-node
netbios-name-server 10.0.1.3
dns-server 10.0.1.3
lease 0 4
vpdn enable
vpdn ip udp ignore checksum
vpdn-group home-pptp
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Ethernet0
description Local LAN
ip address 10.0.1.2 255.255.255.0
load-interval 60
hold-queue 100 out
interface Virtual-Template1
ip unnumbered Ethernet0
peer default ip address dhcp-pool local-POOL
no keepalive
ppp authentication chap
line vty 2 4
exec-timeout 20 0
privilege level 15
login local
transport preferred all
transport input all
transport output all
I can establish a VPN tunnel between my laptop and the server. But i cannot able to ping any systems inside the network.
Once again i am asking for some ones help.
Rajesh
Re: VPN issues
It was all working fine with the same config with a 1800 series router.
But still not yet sure, how and why its working. I did 2 things at a time. Replaced the older router with 1800 router and reloaded the router.
So, not clear what made to work. If some one have any idea please share here.
Rajesh
Re: VPN issues
I feel Cisco 1800 series routers doesn't support PPTP support..
do refer this link which is very much similar inline with your problem.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Virtual%20Private%20Networks&topic=Services&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddbdaee
regds
135
