Community Member
VPN Not Working
Hello
kindly check attachment
10xs
Ali
Re: VPN Not Working
Are the tunnel destination reachable from both ends? i do not see any routes except for one static route to tunnel
can you post sh ip route
Can you also add the transform set under the crypto profile
crypto ipsec profile VTI
set transform-set ali
Narayan
Community Member
Re: VPN Not Working
Hi Narayan
the tunel interface on both side are Down:
Tunnel0 192.168.3.2 YES manual reset down
sh ip route
Gateway of last resort is not set
C 192.1.1.0/24 is directly connected, Serial1/1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
Router-A#
Community Member
Re: VPN Not Working
new entry:
Tunnel0 192.168.3.1 YES manual up down
ROUTER-B#sh crypto isakmp sa
dst src state conn-id slot status
192.1.1.1 193.1.1.1 MM_NO_STATE 0 0 ACTIVE (deleted)
10xs
Re: VPN Not Working
Ali,
How are routerA and router B connected?
with the information you provided, routerA does not seem to have a route for the tunnel destination and hence the tunnel is not coming up. The VPN will come up only when your tunnel is up
Narayan
Re: VPN Not Working
Ali,
Add static route to the tunnel destination address on both routers. You should be able to ping the GRE tunnel IP address of each other. IPSEC SA should come up after that.
Sundar
Community Member
Re: VPN Not Working
hello sundar!
we have already static route configured;plz check attachment
10xs
Ali
Re: VPN Not Working
are these routers connected directly?
Community Member
Re: VPN Not Working
Hello
yes they are;via serial interface
10xs
Re: VPN Not Working
Ali,
The static route(s) you have is for the LAN at the far end but you need a static route to get to the tunnel destination address itself. Can you add the following static routes on both routers. This would cause the tunnel int to come up and you should be able to ping the tunnel IP of each other router.
Router-A:
ip route 193.1.1.1 255.255.255.255 (next-hop-address)
Router-B:
ip route 192.1.1.1 255.255.255.255 (next-hop-address)
Sundar
Re: VPN Not Working
I just noticed you posted that these are routers are directly connected to each other via serial int. If they are directly connected to each other the serial interface of both routers need to be on the same subnet. Can you reconfigure it that way.
Re: VPN Not Working
Ali,
The serial interfaces are connected together but yet in o yur configuration they lie in a seperate subnet
on router B configure
interface Serial1/2
ip address 192.1.1.2 255.255.255.0
interface Tunnel0
tunnel source 192.1.1.2
tunnel destination 192.1.1.1
On router A
nterface Tunnel0
tunnel source 192.1.1.1
tunnel destination 192.1.1.2
and also set the transform set under the crypto profile
have a look at this for an example configuration
http://www.cisco.com/en/US/products/ps6635/products_white_paper0900aecd8029d629.shtml
HTH, rate if it does
Narayan
Community Member
Re: VPN Not Working
Freinds Narayan;sundar
10xs for all ur replys
realy 10xs
Ali
Community Member
Re: VPN Not Working
hello
how can i fix this:
*Mar 1 23:03:17.994: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 192.1.1.1
Re: VPN Not Working
this generally means the devices are not configured with the same properties.
Make sure the profile parameters are similar in both the peers otherwise negotiations will fail
Narayan
Hall of Fame Super Blue
Re: VPN Not Working
Hi Ali
For Cisco error message doc
%CRYPTO-6-IKMP_MODE_FAILURE : Processing of [chars] mode failed with peer at [IP_address]
Explanation Negotiation with the remote peer has failed.
Recommended Action If this situation persists, contact the remote peer.
You may see this even if you successfully negotiate a tunnel. Could you post full debug when tunnel is failing.
Jon
Community Member
Re: VPN Not Working
HELLO Experts!
the error was here:
crypto isakmp key 6 cisco123 address 193.1.1.1 no-xauth
i adjusted it to 192.1.1.2
10xs a lot
Re: VPN Not Working
Good to know that you got it working :-)
Community Member
Re: VPN Not Working
freind!
this is from ur help to me
10xs
Ali
Community Member
Re: VPN Not Working
Hello!
Router-A#show crypto session detail
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, X - IKE Extended Authentication
M - Continuous Channel Mode
Interface: Tunnel0
Session status: UP-ACTIVE
Peer: 192.1.1.2 port 500 fvrf: (none) ivrf: (none)
Phase1_id: 192.1.1.2
Desc: (none)
IKE SA: local 192.1.1.1/500 remote 192.1.1.2/500 Active
Capabilities:(none) connid:1 lifetime:23:50:07
IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 0 drop 0 life (KB/Sec) 4413422/3010
Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 4413422/3010
S 192.168.2.0/24 is directly connected, Tunnel0
C 192.168.3.0/24 is directly connected, Tunnel0
Router-A#
Router-A#s
FastEthernet0/0 192.168.1.1 YES manual up up
Serial1/0 unassigned YES unset administratively down down
Serial1/1 192.1.1.1 YES manual up up
Serial1/2 unassigned YES unset administratively down down
Serial1/3 unassigned YES unset administratively down down
Tunnel0 192.168.3.1 YES manual up up
Router-A#sh crypto isa
Router-A#sh crypto isakmp sa
192.1.1.2 192.1.1.1 QM_IDLE 1 0 ACTIVE
242
