Webcast-Catalyst9k
VPN router at hub site to terminate 30 LAN to LAN VPN
I have 30 locations. We are going to use VPN tunnels over a DSL connection to connect back to the hub site. What type of router should I use at the hub site. Would a 2811 do the job?
1 ACCEPTED SOLUTION
Re: VPN router at hub site to terminate 30 LAN to LAN VPN
We are currently using a 2811 as our VPN termination
point. It has worked quite well. Nice thing is you can easily route between your spokes if needed and the 2811 has enough horse power to handle what you are looking to do.
thank you!
107
