VPN routing stops
Like i said in my last post, the VPN's are now coming up but now i have a VERY strange routing issue.
When i delete the default route (0.0.0.0 0.0.0.0) the VPN's stop routing, even though the VPN connections stay active and i can still ping the external interface.
Gateway of last resort is 211.x.x.1 to network 0.0.0.0
200.x.x.0/32 is subnetted, 1 subnets
S 200.x.x.226 [1/0] via 200.x.x.1
10.0.0.0/15 is subnetted, 1 subnets
C 10.160.0.0 is directly connected, Vlan2
C 211.x.x.0/24 is directly connected, FastEthernet0
C 192.168.100.0/24 is directly connected, Vlan1
219.x.x.0/32 is subnetted, 1 subnets
S 219.x.x.226 [1/0] via 200.x.x.1
S* 0.0.0.0/0 [1/0] via 200.x.x.1
C 242.x.0.0/16 is directly connected, Dialer1
The two static routes with the 32 mask are for the vpn's.
When i delete/change the default static route (S* 0.0.0.0/0 [1/0] via 200.x.x.1) routing stops on the vpns
Some added info. the 10.0.0.0 network is the primary network, and the 192.168.100.0/24 is the secondary private network which has a NAT rule for (C 242.x.0.0/16 is directly connected, Dialer1)
1 REPLY
Re: VPN routing stops
Can you please upload the running config?
Mano
244
