Community Member
VPN site to site doesn't work?
Dear All,
Please help me to verify configuration as in attach file.
i did VPN site to site, so my configuration the tunnel is up already but the IP sec it not working.
So from client HQ cannot ping to client Branch( i mean cannot access anything ).
Could you help to verify on this ?
Best Regards,
Rechard
Community Member
Re: VPN site to site doesn't work?
Hi rechard,
If everything seems ok for u then May be the problem exists because of IP NAT,try the configuration without IP NAT
1) Crypto ACL (ACL 176) is incorrect on both routers.
On HQ, it should be as follows:
access-list 176 permit ip 192.168.51.0 0.0.0.255 192.168.50.0 0.0.0.255
On Branch, it should be as follows:
access-list 176 permit ip 192.168.50.0 0.0.0.255 192.168.51.0 0.0.0.255
2) Further to that, the NAT ACL (ACL 175) is also incorrect.
access-list 175 deny   ip 192.168.51.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 175 permit ip 192.168.51.0 0.0.0.255 any
access-list 175 deny   ip 192.168.50.0 0.0.0.255 192.168.51.0 0.0.0.255
access-list 175 permit ip 192.168.50.0 0.0.0.255 any
Hope that helps.
Community Member
Dear halijenn,
thanks you for your help!!!
Let me follow you!!!!
when i it still problem, how can i fix next?
Best Regards,
Rechard
Should work after the changes. If it still doesn't work, please re-post the latest configuration from both sides, and also the output of "show cry isa sa" and "
show cry ipsec sa".
281
