Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VPN urgent help
guys we have a pc which up loads and downloads files to a remote server at the other site....both the sites are connected via FR link....customer doesnt want permanent VPN......now only one pc does the uploads and downloads.....there requirment is that ..they only want VPN from that pc to the remote site only when the pc is uploading or downloading files as soon as its done the VPN shd be disconnected.....guys can someone recommend any solution any VPN client or some other thing.......i cant get my head around it plz help...thanks in advance
Re: VPN urgent help
Cisco VPN client.
Re: VPN urgent help
Thanks for your help but can you plz explain the whol setup.....do i need any thing on the remote end router....plz explain a bit thanks in advance
81
