VRF across L3 switch link
I have two 3560s connected via a Layer 3 portchannel. I have two vlans on switch A and one VLAN on switch B that i want to be in the same VRF. The rest of the VLANs on both switches i dont want in a VRF...
Im using OSPF for VRF and non VRF router advertisements...
how can i do this with an L3 link connecting the two switches?
TIA
  • WAN Routing and Switching
Re: VRF across L3 switch link
If i understand you correctly, i think you can have the desired vlans with the same RT & RD values and enable VRF FWD on those particular vlan SVI's?
Narayan
If it is VRF lite, the easiest way would be to crate a GRE tunnel between the two switches and put it in your VRF. So assuming each switch has a Loopback address of 192.168.1.1 and 192.168.1.2 it would look as follows;
interface Tunnel1
description VRF Link between switches
ip vrf forwarding VRF_NAME
ip address 10.0.0.1 255.255.255.252
tunnel source Loopback0
tunnel destination 192.168.1.2
router ospf xxxx
address-family ipv4 vrf VRF_NAME
network 10.0.0.0 0.0.0.3 area 0
That would create a L3 link across the GRE tunnel in your VRF and allow OSPF to establish a neighbor for that particular VRF.
Then just place the VLAN SVI's into your vrf;
interface Vlan100
If you previously had an IP address assigned to the SVI, you will need to reassign it after putting it in a VRF.
195
