Community Member
VRF and VLAN
Hi : I am looking for configuration assistance with VRF and VLAN.
running BGP routing protocol per VRF
thank you
Re: VRF and VLAN
You should most probably have a one-to-one relation between VRFs and VLANs according to your design.
As for configuring BGP per VRF, you need to use address-families, something like this:
ip vrf test
rd
interface x
ip vrf forwarding test
ip address x.x.x.x
router bgp
address-family ipv4 vrf test
neighbor remote-as
network mask
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Silver
Re: VRF and VLAN
just a little specification:
interface x = interface vlan x ;)
interface vlan x
ip vrf forwarding
ip address x.x.x.x
Andrea
Re: VRF and VLAN
Hi Andrea,
You are most probably right :)
But i didn't know the original poster's topology (i mean how does he do the inter-VLAN routing), he might be doing router-on-a-stick, and thus i gave it to him in a generic manner and he should work it out.
BR,
Mohammed Mahmoud.
Silver
Re: VRF and VLAN
Yes, Mohammed,
you are right :)
The original post is generic ...
Andrea
467
