VRF import map does not work
Hello. I have a problem. I have two VRFs:
ip vrf customer1
description for_customer1
rd 65000:100
route-target export 65000:100
route-target import 65000:100
ip vrf customer2
description for_customer2
rd 65000:101
import map IMPORT_ROUTES
export map FROM_2_to_1
route-target export 65000:101
route-target import 65000:101
And routing tables:
R11#sh ip route vrf customer1
Routing Table: customer1
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
B    192.168.10.0/24 [200/0] via 6.6.6.6, 00:03:24
     172.16.0.0/24 is subnetted, 1 subnets
B       172.16.9.0 [20/0] via 192.168.22.1 (customer2), 00:03:24
     110.0.0.0/32 is subnetted, 1 subnets
C       110.110.110.11 is directly connected, Loopback11
C    192.168.21.0/24 is directly connected, FastEthernet1/0.21
R11#sh ip route vrf customer2
Routing Table: customer2
B    200.200.200.0/24 [20/0] via 192.168.22.1, 00:03:31
     172.16.0.0/24 is subnetted, 4 subnets
B       172.16.39.0 [20/0] via 192.168.22.1, 00:03:31
B       172.16.29.0 [20/0] via 192.168.22.1, 00:03:31
B       172.16.19.0 [20/0] via 192.168.22.1, 00:03:31
B       172.16.9.0 [20/0] via 192.168.22.1, 00:03:31
B    192.168.21.0/24 [20/0] via 192.168.22.1, 00:03:31
     9.0.0.0/32 is subnetted, 1 subnets
B       9.9.9.9 [20/0] via 192.168.22.1, 00:03:31
C    192.168.22.0/24 is directly connected, FastEthernet1/0.22
By import map IMPORT_ROUTES i want to import route 192.168.10.0/24 from vrf customer1 to customer2. Here is route-map config:
route-map IMPORT_ROUTES permit 10
match ip address prefix-list IMPORT_PREFIX
match extcommunity IMPORT
ip prefix-list IMPORT_PREFIX seq 5 permit 192.168.10.0/24
ip extcommunity-list standard IMPORT permit rt 65000:100
But obviously nothing gets imported between VRFs((( Where is the problem?
Harold Ritter
Hi Volodymyr,
The "import map" statement is only used to further refine an import that is already performed by the "route-target import" statement. You therefore need to add "route-target import 65000:100" under "ip vrf customer2" for the "import map" statement to properly do its job.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
Hi Volodymyr,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Yeap, it helped))) Thanks
