VRF Leaking (Bug?)
I am trying to leak specific routes between two VRF's using the following config.
It filters one way, but doesn;t pass any routes the other. If I replace
export map customer-mgt-range
with
route-target import 39097:701
then all routes get learnt. If I then put the original line back in, it all works fine. Looks like a bug to me, but can't find a matching one on CCO.
ip vrf MGT
rd 39097:701
export map mgt-range
route-target import 39097:999
ip vrf TWR1
rd 39097:702
access-list 31 permit 172.31.0.0 0.0.255.255
access-list 32 permit 195.60.197.0
route-map customer-mgt-range permit 10
match ip address 31
set extcommunity rt 39097:999
route-map mgt-range permit 10
match ip address 32
set extcommunity rt 39097:701
Re: VRF Leaking (Bug?)
What version are you running on this router? Cam you include the whole configuration.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
IOS is IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
I'm not really able to post any more config, as it's sensitive!
Just looking to see if there is a known bug initially..
106
