VRF-Lite issue
Hi All,
I've got an issue where I've route leaked two static routes from VRF_A into VRF_B, but only one of them is being inserted into the routing table.  If you look at the BGP table for VRF_B, you can see that 207.219.72.145/32 and 172.16.20.0/24 are in there, however only 172.16.20.0/24 is in the routing table.  I need to be able to put 207.219.72.145/32 so it can perform recursive lookup.
Any help on why it's not inserting this BGP route into the RIB?
XXXXXX#sh ip bgp vpnv4 all
Route Distinguisher: 6500:102 (default for vrf VRF_A)
*> 10.127.6.0/24    207.219.72.145           0         32768 ?
*> 149.122.0.0      172.22.224.1             0         32768 ?
*> 172.16.20.0/24   207.219.72.145           0         32768 ?              <<<<<<<<<<<
*> 172.22.0.0/15    172.22.224.1             0         32768 ?
*> 172.22.225.0/24  0.0.0.0                  0         32768 ?
*> 172.24.0.0/15    172.22.224.1             0         32768 ?
*> 207.219.72.145/32       0.0.0.0                  0         32768 ?            <<<<<<<<<<<
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 6500:2 (default for vrf VRF_B)
r> 172.22.225.0/24  0.0.0.0                  0         32768 ?
*> 172.22.226.0/24  0.0.0.0                  0         32768 ?
*> 172.22.252.0/24  172.22.226.3          1001         32768 ?
*> 172.24.252.192/28       172.22.226.17         1001         32768 ?
*> 172.24.252.208/28       172.22.226.18         1001         32768 ?
XXXXXXXX#sh ip route vrf VRF_B 172.16.20.0
Routing Table: VRF_B
Routing entry for 172.16.20.0/24
  Known via "bgp 65534", distance 20, metric 0, type external
  Redistributing via ospf 64521
  Last update from 207.219.72.145 1d01h ago
  Routing Descriptor Blocks:
  * 207.219.72.145 (VRF_A), from 0.0.0.0, 1d01h ago
      Route metric is 0, traffic share count is 1
      AS Hops 0
      MPLS label: none
XXXXXXXX#sh ip route vrf VRF_B 207.219.72.145
% Network not in table
ip vrf VRF_B
rd 6500:2
route-target export 300:2
route-target import 300:3
ip vrf VRF_A
rd 6500:102
route-target export 300:3
route-target import 300:2
Everyone's tags (3)
248
