Community Member
VRF lite: unreachable
I was configuring two routers connected to each other with serial0/1 interfaces. I configured ip vrf forwarding on the sub interfaces however both routers cannot reach each other through the vrf instances.
vrf13#
interface Serial0/1.1
ip vrf forwarding test
ip address 1.1.1.1 255.255.255.252
end
ip vrf test
rd 13:1
vrf14#
ip address 1.1.1.2 255.255.255.252
end
ip vrf test
vrf14#
vrf13#sh ip vrf test
  Name                             Default RD          Interfaces
  test                             13:1                Se0/1.1
vrf13#
vrf13#sh ip route vrf test | begin Gateway
Gateway of last resort is not set
     1.0.0.0/30 is subnetted, 1 subnets
C       1.1.1.0 is directly connected, Serial0/1.1
vrf13#
vrf13#show ip interface brief | i Serial0/1.1
Serial0/1.1                1.1.1.1         YES manual up                    up
vrf13#
vrf14#sh ip vrf test
  test                             14:1                Se0/1.1
vrf14#
vrf14#sh ip route vrf test | begin Gateway
vrf14#
vrf14#show ip interface brief | i Serial0/1.1
Serial0/1.1                1.1.1.2         YES manual up                    up
vrf14#
vrf13#ping vrf test 1.1.1.2
Sending 5, 100-byte ICMP Echos to 1.1.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
vrf13#
vrf14#ping vrf test 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
No frame relay, it is just a router to router connection.
Did I miss anything? Just vrf lite without bgp....i suppose i do not need to use export rt and import rt since there is no bgp....
Everyone's tags (1)
1 ACCEPTED SOLUTION
Community Member
Re: VRF lite: unreachable
It should work. Can you ping the interfaces without vrf forwarding enabled on the interfaces?
Community Member
Community Member
thanks i have solved the problem myself. thanks for the reply.
Silver
looks like, you are missing route distinguisher on vrf14
Posted by WebUser Neeraj Jagga from Cisco Support Community App
Community Member
Problem is not with route distinguisher
vrf14#
end
  test                             14:1                Se0/1.1
vrf14#
Even without route distinguisher, it will work on the interface level by merely define the ip vrf instance as shown in one of the post by packetlife.
I have written the findings here https://cyruslab.wordpress.com/2012/05/02/mpls-vpn-vrf/
I used fa interface instead of serial interface.
456
