Webcast-Catalyst9k
vrf lite
Good mooring,
Please,i need a simple configuration example with vrf between 2 routers acts as PE and P.
Regards.
Re: vrf lite
Hi Stephane
Generally you wont have VRF configs in P-Router yes off course you will have VRF's in PE routers configured for different customers which is unique to them.
P- Routers actually have the Labels to reach the respective PE routers ...
regds
Re: vrf lite
in my case it is vrf lite, means without mpls.
If you have proposal don't hesitate, i want test a simple configuration to understant vrf well.
138
