VRF Receive connected routes won't redistribute
For some reason if I setup a vrf receive route for incoming connected connections the router will see them but will not redistribue the connected routes.
If I do a "show ip route vrf customer1 connected" it shows all of the routes fine.
If I setup a static route then this redistributes fine to other routers and if I setup a vrf forwarding route this will also redistribute fine.
It's only vrf receive connected routes which do not seem to redistribute. I've checked the Cisco bug search tool but cannot see this particular issue but I've gone through everything and I cannot see why they will not redistribute.
Any ideas?
Sorry, I should have
Sorry, I should have clarified. This is redistributing into a MBGP network/Full mesh.
All other VRF's and routers are redistributing fine. Only VRF receive connected routes do not.
thanks
Hello.Could you please
Hello.
Could you please provide the configuration you are using and show commands for your MBGP?
76
