VSS IOS Upgrade
I am setting up 2x6509s to run VSS. The IOS coming with the boxes are 12.2(33).SXI3. With this IOS I am running into the bug CSCtc41114 (SSH connections fail to the switch). I am looking into upgrading the IOS to 12.2(33).SXI4a. I notices there are 2 different IOS, Modular and non Modular. Can any one tell me what is the different between both and which one I should use. Is it hardware dependant?
IP BASE SSH LAN ONLY
s72033-ipbasek9-mz.122-33.SXI4a.bin
Release Date: 22/Jul/2010
Size: 67180.23 KB  (68792548 bytes)
Minimum Memory: DRAM:1024 MB  Flash:1024
IP BASE SSH LAN ONLY (MODULAR)
s72033-ipbasek9-vz.122-33.SXI4a.bin
Size: 127483.81 KB  (130543412 bytes)
Minimum Memory: DRAM:1024 MB  Flash:1024 MB
Here are the show command from the 6509.
CWCDCCORE1#sh mod
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1428MCYS
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1429MVU4
  3    6  Firewall Module                        WS-SVC-FWM-1       SAL1426LBH5
  4    8  Network Analysis Module                WS-SVC-NAM-2-250S  SAL1420HS3V
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  c84c.75a6.077c to c84c.75a6.07ab   3.4   12.2(18r)S1  12.2(33)SXI3 Ok
  2  c84c.75a1.b95c to c84c.75a1.b973   4.4   12.2(18r)S1  12.2(33)SXI3 Ok
  3  5475.d062.7428 to 5475.d062.742f   4.5   7.2(1)       4.0(4)       Ok
  4  5475.d062.4438 to 5475.d062.443f   1.2   7.2(1)       4.1(1)       Ok
  5  001e.4a7f.1ba8 to 001e.4a7f.1baf   3.2   8.5(4)       12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1428MDD9  4.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1429MZG8  4.1    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1428MH0Q  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1428MDV9  5.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
CWCDCCORE1#
CWCDCCORE1#sh sup-bootf
-#- --length-- -----date/time------ path
1     33554432 Jul 17 2010 01:36:58 -06:00 sea_console.dat
2     56696548 Jul 17 2010 01:39:36 -06:00 s72033-ipbasek9-mz.122-33.SXI3.bin
3     33554432 Jul 17 2010 05:55:02 -06:00 sea_log.dat
4       466004 Sep 27 2010 23:39:10 -06:00 crashinfo_20100927-233910-MDT
900268032 bytes available (124289024 bytes used)
Thanks!!!!!
Everyone's tags (2)
Hall of Fame Super Blue
Re: VSS IOS Upgrade
Joe
Modular IOS breaks down the IOS into separate modules to all intents which allows you to upgrade parts of it without having to upgrade the whole image. However Cisco have announced that they are discontinuing modular IOS so i wouldn't go with that if i was you. Stick with the single IOS image for your VSS upgrade.
Jon
Re: VSS IOS Upgrade
Thanks for you respond. That works out even better. The non modular IOS is smaller size than the modular.
1037
