Community Member
VTP Pruning
I?ve configured vtp pruning but I am still getting broadcast traffic from vlan 6. I just used the vtp pruning command. Do I have to configure anything else to enable pruning?
Re: VTP Pruning
hi,,,
will you clear it in more detail with your connectivity...and problem ...
here you are receiving the broadcast traffice of vlan 6 of one switch to other which is not having the vlan 6 am i right???
Community Member
Re: VTP Pruning
I?ve a 3550,routing between vlan?s. I?ve configured span to monitor one of the fiber ports and I am receiveing broadcast from computers in vlan6. Should I receive this type of traffic?
3550---------------vlan6
fiber |
| ---vlan8------- vlan7
vlan1
vlan1
Community Member
Re: VTP Pruning
It got a little confused, but I?ve a dual ring topology among vlan?s 6,7 and 8 connected through fiber.
Re: VTP Pruning
you can have more information form the given link
http://www.firewall.cx/vlans-vtp-pruning.php
rate this post if it helps
regards
Devang
121
