Webcast-Catalyst9k
VWIC-1MFT-G703 and 2mb Leased Line
We have a customer that has a Leased line provided by BT in the UK.
Each site has a Cisco 2650xm and VWIC-1MFT-G703 cards, The line was a 1Mb connection but has been upgraded to 2Mb.
The current config has the following lines.
controller E1 0/0
line-termination 75-ohm
channel-group 1 timeslots 1-16
I belive that I need to change the time slot to get the full bandwidth? is this correct. I have tried this morning to change the time slots to 1-31 but the line protocol stays down(I did change at both ends)
Any help on this matter would be great.
Simon.
1 REPLY
Re: VWIC-1MFT-G703 and 2mb Leased Line
In addition to altering the timeslots which is required for E1 have you tried changing or configuring the framing parameter ?
it can be configured using the cli - framing no-crc4.
do configure this up and check whether you get the link up or not..
regds
196
