VWIC-1MFT-G703 bridging
Hi All,
Quick question regarding bridging on VWIC-1MFT-G703 cards
Brief scenario:
site A:G.703 cct--->2801<---G.703 cct:site B
Circuits on each site will connect to routers that will provide IP addressing. 2801 in the middle terminating both G.703 circuits. Although the bridge commands are accepted by the 2801 on the serial interfaces, is this feasible to put the two interfaces in the same bridge group and pass traffice between the site routers? Seems easy enough but never done it before.
What do you reckon?
Router(config)#do wr t
Building configuration...
Current configuration : 1047 bytes
version 12.4
hostname Router
boot-start-marker
boot system flash c2801-ipbasek9-mz.124-10a.bin
boot-end-marker
no aaa new-model
no network-clock-participate wic 2
no network-clock-participate wic 3
ip cef
controller E1 0/2/0
framing NO-CRC4
channel-group 1 timeslots 1-31
controller E1 0/3/0
framing NO-CRC4
bridge irb
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0:1
no ip address
encapsulation ppp
bridge-group 1
bridge-group 1 spanning-disabled
interface Serial0/3/0:1
no ip address
encapsulation ppp
bridge-group 1
no ip http server
no ip http secure-server
disable-eadi
control-plane
line con 0
login
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Router(config)#
Cheers
Ali
1 REPLY
Gold
Re: VWIC-1MFT-G703 bridging
Wouldn't it be easier to hook the 2 e1 circuits together with a cross cable.
I have never done this but in theory it should work. I suspect you will have issues if you attempt to put in BVI interfaces since you will then have point to multipoint configurations.
166
