VWIC-1MFT-G703= not working with framerealy encaplsulation
Dear all
Cisco 1841 router with VWIC-1MFT-G703 card , old cards getting error , so we planned replace new VWIC-1MFT-G703 , its detecting but line protocol was down , than we changed another cards also same status ,
Physical loop given ( PIn out 1 and 4 2 and 5 ) , both cards show line protocol up ( looped)
Please suggest any modification required in configuration side ,  Slot 0 ( OLD card ) Slot 1 - New Card
WIC/HWIC Slot 0:
E1 G703 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0          Board revision A0
Serial number     36621247   Part number    800-06722-04
Version Identifier     V02  FRU Part Number     VWIC-1MFT-G703
Test history      0x0          RMA number     00-00-00
Connector type    PCI
EEPROM format version 1
EEPROM contents (hex):
   0x20: 01 2F 01 00 02 2E CB BF 50 1A 42 04 00 00 00 00
   0x30: 50 00 00 00 08 08 18 00 FF FF FF FF FF FF FF FF
WIC/HWIC Slot 1:
Hardware revision 1.0          Board revision E0
Serial number     33597427   Part number    800-06722-02
FRU Part Number     VWIC-1MFT-G703=
Connector type    PCI
   0x20: 01 2F 01 00 02 00 A7 F3 50 1A 42 02 00 00 00 00
   0x30: 70 00 00 00 05 05 26 00 FF FF FF FF FF FF FF FF
Bronze
Re: VWIC-1MFT-G703= not working with framerealy encaplsulation
Hi Siva,
Have you tried in another slot?
It does not look like hardware issue.
The following troubleshooting guide for FR may help you out....
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
we tried three new card  same status , 3 card are view in show diag command , but line protocol down , same slot Old is working with errors.
Physical loop  -- > it Line Protocol UP ,, ( after remove the Frame-relay encapsulation ) ,
580
