Community Member
VWIC 2-Port T1/E1 card in 3825
I have a CESoPSN terminated on a T1 port 0/2/1, See below for configuration.
controller T1 0/2/1
linecode b8zs
cablelength long 0db
cem-group 0 timeslots 1-24
interface CEM0/2/1
no ip address
cem 0
xconnect 10.221.221.87 100 encapsulation mpls
SYS22-Cis#show xconnect all
Legend: XC ST=Xconnect State, S1=Segment1 State, S2=Segment2 State
UP=Up, DN=Down, AD=Admin Down, IA=Inactive, NH=No Hardware
XC ST Segment 1 S1 Segment 2 S2
UP ac CE0/2/1(CESoPSN Basic) UP mpls 10.221.221.87:100 UP
For testing purposes, I wanted to put a loopback cable in the T1 port, so that traffic is looped back over MPLS to the source. However, when I create the loopback cable as shown below, the port does not go green? The document for the VWIC 2T1/E1 card, specifies that the port must use RJ-48C.
Below is my loopback cable. Is this correct?
Pinout:
PIN1: RX Ring <-------\
PIN2: RX Tip <*******|***
PIN3: Reserved | *
PIN4: TX Ring >-------/ *
PIN5: TX Tip >***********
PIN6: Reserved
PIN7: shield
PIN8: Shield
Also, the port is showing that it is UP, with no cable in it. How is this possible?
SYS22-Cis#show interfaces CE0/2/0 description
Interface Status Protocol Description
CE0/2/0 down down
SYS22-Cis#show interfaces CE0/2/1 description
CE0/2/1 up up
Hall of Fame Super Silver
Re: VWIC 2-Port T1/E1 card in 3825
Hello ,
your cable look like correct
see for example:
http://www.chebucto.ns.ca/Chebucto/Technical/Manuals/Max/max6000/gs/cables.htm#17238
table c-5 cross-cover cable
I think that default configuration the T1 will try to get clock from line
clock source line
You could try under controller T1 to add
clock source internal
the other fact that ce0/2/1 unplugged shows up/up makes me wonder too.
Hope to help
Giuseppe
Community Member
So my loopback cable is correct. But it does not work. And I tried making changes to the timing, but that did not change the status of the port. Any other thoughts?
145
