Webcast-Catalyst9k
Bronze
VWIC 2MFT ? G703
Does this card supports ISDN PRI? I.e. i need to connect multiple remote sites to this card, in other words to be aggregation ISDN PRI for remote BRI sites?
As i read at a Cisco document for Cisco 3600 "If you set up the card to use ISDN PRI signaling, there is no support for ISDN data connection. The card cannot terminate ISDN 64K or 56K data connection; the card only supports voice-call termination with ISDN PRI signaling.", i think this valid when it is installed at Cisco 2851?
Thanks in advance
Abd Alqader
Silver
Re: VWIC 2MFT ? G703
According to below product info., it does not mention to support ISDN.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091b9c.html
The function is limited on the module and not the router model. So I believe this module still not able to support ISDN in 2851. However, you can implement fractional T1/E1 instead of PRI if the PTT supports it.
Hope this helps.
Bronze
Hi Jack,
Yes, it seems that.
But what about fractional T1/E1 instead of PRI if the PTT supports it?
Thanks in advance
Abd Alqader
Silver
Please check the provided link that it mentioned to support fractional T1/E1, so I suggest to check w/ PTT for this service availability.
99
