11-27-2006 02:13 AM - edited 03-03-2019 02:49 PM
11-27-2006 02:21 AM
Hi Friend,
Two channel groups can be supported per VWIC2 module. When a 2 port VWIC2 is used, only 1 channel group is supported per port.
http://www.cisco.com/en/US/products/ps5855/products_qanda_item0900aecd8028d2e5.shtml
Ankur
*Pls rate all helpfull post
11-27-2006 02:35 AM
Dear Ankur
what about VWIC ... ?
Your mentioens answer was about VWIC2 , but is it the same for VWIC as well ?
Morteza
11-27-2006 02:46 AM
Hi Morteza,
This will answer all your doubt
Ankur
11-27-2006 08:20 PM
Hi Ankur,
I have a setup wherein i am using a VWIC-1MFT-G703 and have configured 3 channel groups and is working fine
see the below output
controller E1 0/0/0
channel-group 0 timeslots 1-16 speed 64
channel-group 1 timeslots 24-31 speed 64
channel-group 2 timeslots 20-21 speed 64
WIC Slot 0:
E1 G703 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 28182126 Part number 800-06722-02
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 2F 01 00 01 AE 06 6E 50 1A 42 02 00 00 00 00
0x30: 58 00 00 00 02 05 13 00 FF FF FF FF FF FF FF FF
Narayan
11-28-2006 03:18 AM
Hi Narayan
You can configure more than 2 channel group in VWIC2.The channel-group limits depend on where you insert the VWIC2.
e.g. in Case of 3800 HWIC slots: max 128 channel-groups across all 4 HWIC slots & in case of 2800 it's limited to 2 channel groups per HWIC slot.
Also limitation is per slot & not on VWIC2 port
