VWIC Module
Dear all,
Kindly i want to know some information about the following module that will be installed in Cisco 3845 ISR router:
VWIC-2MFT-G703
Does this module support Channalized E1s and How many Channel groups support in each port?
i tried in cisco.com but it said that supporting channel groups but not numbering of these groups
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
Thanks alt
1 REPLY
Re: VWIC Module
The this VWICs supports a channelized capability where the T1 or E1 service can be flexibly split into two or more fractional channel groups. Thus a single physical port can provide connection to multiple sites.
As channeling capability is there , you can number the channels , otherwise you cannot split E1 into multiple channel groups.
For E1 you can support 30 channel groups.
HTH..rate if helpful..
132
