VWIC2-1MFT-T1/E1 + Data Calls
Frank.Watzka
I'm using a C2901 SecLicense with a VWIC2-1MFT-T1/E1-Card in order to make E1 Data Calls. The Documentation
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/intserv.html#wp1043332 states that this card supports data calls.
But this did not work. A SE told me that I have to use PVDMs & NM-HDV2 in order to get this working. Is this right?
Thank You
Frank
9 Replies 9
nisagar
Can you send me the sh diag of your router hardware info ?
To support PRI data calls, a VWIC-1MFT-E1 voice cards must have a packet voice data module (PVDM).
Also note that it has been mentioned that  supported modules are:
-NM-HD
-NM-HDV2
-Onboard DSPs
So you either need onboard DSPs (PVDM will provide it) or NM with DSP onboard like cards above.
You also need to enable integrated services with command "isdn integrate calltype all "
Isn't there a difference between the VWIC2- and the VWIC-cards? Do they both require PVDMs?
Q. How do the Cisco VWIC2 cards differ from  the previous generation VWIC cards?
A. The Cisco VWIC2 cards add numerous enhancements to the previous  generation Cisco VWIC cards. These improvements include:
Dedicated  echo-cancellation option: The Cisco VWIC2 cards have an onboard  slot for an optional Cisco Dedicated Echo Cancellation Module (part  number EC-MFT-32 or EC-MFT-64), offering an enhanced echo-cancellation  capability for demanding network conditions requiring up to 128 ms of  echo tails.
Support for both T1 and  E1: The Cisco T1/E1 VWIC2 cards support both T1 and E1, providing  additional flexibility in configuring the VWIC2 cards for supporting  T1, fractional T1, E1, and fractional E1 for both voice and WAN  applications.
Drop-and-insert  capability on all versions: All Cisco VWIC2 modules now include  the drop-and-insert multiplexing capability, eliminating costly external  third-party channel service units/data service units (CSUs/DSUs) and  drop-and-insert multiplexers.
Enhanced clocking  capabilities: The Cisco 2-port VWIC2 cards can enable each port  to be clocked from independent clock sources for data applications. This  independent clocking capability is not supported for voice applications  or with the Cisco ATM/Voice Advanced Integration Modules (part numbers  AIM-ATM, AIM-VOICE-30, and AIM-ATM-VOICE-30).
nisagar
Please also ellaborate your physical topology , circuit, router sh diag etc.
Hi Nitin,
from the debugs:
ISDN Se0/0/0:15 **ERROR**: accept_incoming_data: no hdlc available from controller b channel 18, call id 0x13
Toplogy - very simple: E1 to outside, Gi0/0 to inside with default route to firewall
some parts from show tech:
***#show tech-support
------------------ show version ------------------
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 15:41 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
*** uptime is 29 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ152270PK
2 Gigabit Ethernet interfaces
31 Serial interfaces
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#  PIDSN
*0    CISCO2901/K9          FCZ152270PK
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          None          None          None
------------------ show running-config ------------------
Building configuration...
Current configuration : 106641 bytes
! Last configuration change at 17:31:18 MEST Fri Sep 16 2011 by root
version 15.0
service timestamps debug datetime msec show-timezone year
service timestamps log datetime msec show-timezone year
hostname *****
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login TEMP local
aaa authentication ppp default group tacacs+
aaa authorization network default group tacacs+
aaa accounting update newinfo
aaa accounting network default
action-type start-stop
group tacacs+
aaa session-id common
clock timezone MET 1
clock summer-time MEST recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 0
no ipv6 cef
no ip source-route
ip cef
no ip domain lookup
ip domain name ***.***
virtual-profile virtual-template 1
isdn switch-type primary-net5
controller E1 0/0/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
description DMZ
ip address 192.168.254.2 255.255.255.0
ip accounting access-violations
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
description Einwahlknoten Tel.: *****
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
dialer-group 1
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0
ip nat outside
no peer default ip address
ppp authentication chap
interface Dialer1
ip access-group 110 in
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer-group 1
ip local pool notebook-pool 192.168.253.1 192.168.253.254
ip local pool steuerung-pool 192.168.252.1 192.168.252.254
ip forward-protocol nd
ip nat translation timeout 1000
ip nat pool net_i-o 192.168.254.129 192.168.254.253 netmask 255.255.255.128
ip nat inside source list 2 pool net_i-o
ip route 0.0.0.0 0.0.0.0 192.168.254.1
ip route 1.168.12.221 255.255.255.255 Dialer1
ip route 192.16.2.193 255.255.255.255 Dialer1
ip route 192.168.0.0 255.255.0.0 Dialer1
Frank
Hi Frank,
I see currently you have a VWIC2 but no PVDM2x. If you have PVDM2 and
the VWIC2 running this IOS, you should be able to support Data PRI
calls.
 VWIC2-1MFT-T1/E1: What you currently have requires PVDM2 DSPs:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016e845_ps3115_Products_Data_Sheet.html
Hi Nitin,
thank you. Do I also need a NM-HDV2-1T1/E1?
Kind regards
Frank
Hi Frank,
No, you do not need this card. You just need an PVDM2 module with your exisiting VWIC2-1MFT-T1/E1 card.
Nitin Sagar
Hi Frank,
This is what iam suggesting as per your current hardware you have i.e. VWIC2-1MFT-T1/E1, if you want you can use this card also but the purpose can be completed if you use the above mentioned combination.
Nitin Sgaar
