VWIC2-1MFT-T1/E1 IOS required
I am currently running IOS version c1700-ipvoice-mz.123-14.T5 to support the Vwic2-1mft-t1/e1 interface card on a 1760 Router. We have introduced BGP into our network and the above IOS version does not support BGP. TAC was contacted and the IOS versions they suggested did not work. The new IOS versions gave me BGP but the above wic no longer was seen by the new IOS. What is the IOS "feature" needed to support this card?
Re: VWIC2-1MFT-T1/E1 IOS required
Thomas,
The feature set "IPVoice" that you are running on the 1760 does not support BGP.
You have three choices:
1. Advanced IP Services
2. Enterprise Services
3. Advanced Enterprise Services
Before you upgrade the router to any one of the above feature set, make sure that the router has sufficient Flash and RAM.
References:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/prod_bulletin09186a00801af451.html
http://www.cisco.com/en/US/partner/products/ps5855/products_data_sheet0900aecd8028d2db.html
Let me know if it helps.
Arul
Thomas,
you would require at least 12.3(14)T IOS to support the 2nd generation card and minimum of the above feature sets for BGP support.
I would suggest the foolowing IOS
c1700-advipservicesk9-mz.12.3-14.T7.bin
Note: DRAM / Min Flash = 96 / 32
Narayan
Thanks, that did the trick
The references on IOS versions and features were a big help, thanks
401
