Webcast-Catalyst9k
VWIC2-1MFT-T1/E1 on Cisco2801
Dear All
I have two Cisco2801 routers with VWIC2-1MFT-T1/E1 modules and I want to interconnect them by E1 (RJ-48) crossover cable for IP traffic exchange.
I must use Dial-on-Demand Routing.
I tried "ISDN DDR Using HDLC Encapsulation" example
(http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a00800945be.shtml)
- ISDN call is placed, but IP traffic doesn't pass through E1 link. Here some debug outputs:
Cisco1#ping 192.168.1.2
000198: *Sep 19 18:51:32.391 PCTime: IP: tableid=0, s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), routed via RIB
000199: *Sep 19 18:51:32.391 PCTime: IP: s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), len 100, sending
000200: *Sep 19 18:51:32.391 PCTime: ICMP type=8, code=0
000201: *Sep 19 18:51:32.395 PCTime: Se0/1/0:15 DDR: place call
000202: *Sep 19 18:51:32.395 PCTime: Se0/1/0:15 DDR: Dialing cause ip (s=192.168.1.1, d=192.168.1.2)
000203: *Sep 19 18:51:32.395 PCTime: Se0/1/0:15 DDR: Attempting to dial 310000
000204: *Sep 19 18:51:32.395 PCTime: IP: s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), len 100, encapsulation failed
000205: *Sep 19 18:51:32.395 PCTime: ICMP type=8, code=0
000208: *Sep 19 18:51:32.395 PCTime: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 310000
000209: *Sep 19 18:51:32.399 PCTime: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0008
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x81, '310000'
Plan:ISDN, Type:Unknown
000210: *Sep 19 18:51:32.411 PCTime: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8008
000212: *Sep 19 18:51:32.415 PCTime: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8008
000214: *Sep 19 18:51:32.415 PCTime: %LINK-3-UPDOWN: Interface Serial0/1/0:0, changed state to up
000215: *Sep 19 18:51:32.415 PCTime: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 310000 N/A
000217: *Sep 19 18:51:32.419 PCTime: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0008
000218: *Sep 19 18:51:32.419 PCTime: Se0/1/0:0 DDR: dialer protocol up.
000219: *Sep 19 18:51:33.415 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0:0, changed state to up
000220: *Sep 19 18:51:34.391 PCTime: IP: tableid=0, s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), routed via RIB
000221: *Sep 19 18:51:34.391 PCTime: IP: s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), len 100, sending
000222: *Sep 19 18:51:34.391 PCTime: ICMP type=8, code=0.
000229: *Sep 19 18:51:40.391 PCTime: IP: tableid=0, s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), routed via RIB
000230: *Sep 19 18:51:40.391 PCTime: IP: s=192.168.1.1 (local), d=192.168.1.2 (Serial0/1/0:15), len 100, sending
000231: *Sep 19 18:51:40.391 PCTime: ICMP type=8, code=0
000232: *Sep 19 18:51:41.095 PCTime: Serial0/1/0:0: HDLC myseq 0, mineseen 0, yourseen 0, line up .
Success rate is 0 percent (0/5)
When I try to configure PPP encap on the Serial x/x/x:15, Layer2 of E1 link goes down at all and I can't to place ISDN calls.
I posted description of this trouble two weeks ago in "Remote Access" section - some people said me, that if I'm using a Dialer, I can't establish PPP connection with such VWICs modules!? Is that true?
Experts!!! please, help me!
Thanks in advance
Re: VWIC2-1MFT-T1/E1 on Cisco2801
Could you please post the actual config and the output from: deb ppp neg?
Leo
Hi Leo
In actual config of my routers PPP encap is not configured. I would like to know, why HDLC encap doesn't work properly? According to their example ("ISDN DDR Using HDLC Encapsulation") it must work. All difference: they are using BRI, and I'm using PRI. I thought, that BRI and PRI are the same in configuration.
Here some relevant config from my routers:
Router A (network side)
hostname Cisco1
network-clock-participate wic 1
ip subnet-zero
ip cef
no ip dhcp use vrf connected
isdn switch-type primary-net5
controller E1 0/1/0
clock source internal
pri-group timeslots 1-31
interface Serial0/1/0:15
isdn protocol-emulate network
dialer map ip 192.168.1.2 broadcast name Cisco2 310000
dialer-group 1
no fair-queue
ip classless
access-list 105 permit icmp any any
dialer-list 1 protocol ip permit
Router B (user side)
hostname Cisco2
ip subnet-zero
ip cef
controller E1 0/1/0
clock source line
ip address 192.168.1.2 255.255.255.0
dialer map ip 192.168.1.1 broadcast name Cisco1 210000
dialer-group 1
no fair-queue
ip classless
As for PPP, I told, that I see TEI_ASSIGNED instead of MULTIPLE_FRAME_ESTABLISHED, one I configure PPP encap on the Serial0/1/0:15. Is it normal for PPP? I don't know. But how to place the calls, when Layer2 doesn't work?
Please help!
Ivan
Now, it looks from your config as if you are connecting the modules back-to-back. As far as I know, this will not work. You always need a public exchange in between for proper signalling.
It is perhaps possible to use a channelized connection:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a0080087328.html#4669
Otherwise you need to use the vwic-1mft-g703 module which is capable of using the external E1 circuit as a leased line.
Leo
Hi Leo!
You were rihgt! We realy have wrong modules. We want use ISDN PRI for data, but VWIC MFT modules don't support that.
Here some notes form Cisco documentation:
** If you set up the card to use ISDN PRI signaling, there is no support for ISDN data
connection. The card cannot terminate ISDN 64K or 56K data connection; the card only
supports voice-call termination with ISDN PRI signaling.
We contacted with Cisco TAC support team and they suggested us to use NM-1CE1T1-PRI 1-port Channelized E1/T1/ISDN PRI network module, if we want to use ISDN PRI for data.
I rated your post, because it was also very helpfull.
Many thanks
Ivan
939
