VWIC2-2MFT-T1/E1 ethernet card
I have a VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on cisco router 2801. what interface to setup for this card?
  • WAN Routing and Switching
Hall of Fame Super Gold
Re: VWIC2-2MFT-T1/E1 ethernet card
That is not an ethernet card, it is a WAN or Voice T1/E1 card. What do you need to do ?
first of all you need select a type T1 or E1
card type {t1 | e1} slot [bay]
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_c2_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1124401
after that you will get in the configuration T1 or E1 controller.
it got two ethernet port. need combine them as a single E1 circuit
WIC/VIC/HWIC Slot 1:
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Deviation Number : 95966
Fab Version : 04
PCB Serial Number : FOC12220LH6
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 01 76 DE 02 04 C1 8B 46 4F 43 31
0x20: 32 32 32 30 4C 48 36 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hi, ethernet is the LAN thing, the connector with 8 pins is called RJ-45 and sometime RJ-48.
Do you have the circuit active and delivered already ?
yes circuit is active connected to a MUX. just need to setup the VWIC card on the router and combine both E1's as a single circuit
card type E1
network-clock-participate wic
network-clock-select 1 E1 /0
network-clock-select 2 E1 /1
controller E1 0//0
channel-group 0 timeslots 1-31
controller E1 0//1
The serial interfaces will appear, configure as usual with DEFAULTS, I recommend that initially you do NOT use multilink PPP to test the circuit first, after that you can look into "combining".
i only have one card in slot 1
Then replace with 1 and enter the commands above.
As an appreciation for those providing answers, please rate useful posts with the scrollbox below!
paolo,
i now have
controller E1 0/1/0
controller E1 0/1/1
interface Serial0/1/0:0
no ip address
interface Serial0/1/1:0
no ip address
i gues i need to use multilink ppp to combine both serial sub interfaces right?
1555
