VWIC2-2MFT T1 S0/0:0 Input Errors and CRC
I have a VWIC2-2MFT-T1/E1 in a C3745 Slot 0 used for data only. When I run a BERT from the T-BERD or from the 3745 I get no errors, but the serial interface is show that input errors and CRCs are incrementing at the same rate. In roughly 1 hour it took 35000 crcs. I can still ping the far end router. (Which isn't under my control).
Settings:
b8zs
esf
timeslots 1-24 speed 64
timeing from line
both ends have matched setting according to my counter-part for remote router.
Any thoughts?
John
1 REPLY
Re: VWIC2-2MFT T1 S0/0:0 Input Errors and CRC
Take care that the modem and the 3745 are both properly grounded. With VWIC modules, this is very important.
Leo
130
