04-04-2012 02:44 AM - edited 03-04-2019 03:54 PM
I have a 2921 router, with UCK9 services on it. I've installed a VWIC2-2MFT but the system is not seeing it. I've been told there is a command required to enable the card, is this true? If so, can anyone point me in the right direction with regards to the command? I've always done most of my UC work on the 2800 range and never had to run an enable command, it just saw the card.
Kind regards
Neil
04-04-2012 03:49 AM
Can you post "show inventory"?
04-04-2012 03:54 AM
You need to configure card type.
That is often asked if you had taken the time to search before asking.
04-04-2012 03:59 AM
Thanks for your replies. I've been having several discussions onsite where I am with other engineers. It looks like I was given false advice and there is no additional command (I had already added the card type command, hence why I was confused it didn't work). After some further investigation it looks like I've got a faulty VWIC so I'm going to replace the card.
Thanks your help, I really appreciate it.
04-04-2012 04:02 AM
What are the symptoms for which you say it doesn't work ?
Can you configure under relevant controller ?
04-04-2012 04:13 AM
The router will not take the card type command, show inventory does not see the card. I've tried the card in another, brand new chassis and it does not work in that either. I have tried a new card and this now works fine. It was the wrong advice I was given by an engineer onsite this end, that threw me and pushed me to ask the question on the support forum, as I had searched high and low for an additional command required......which I have now realised doesn't exist.
Thanks for your assistance.
