Community Member
VXR 7206 / PA-2T3
I am trying to figure out if I can can channelize 1 DS3 port of a PA-2T3 and have the other port non-channelized, which is interfaces 6/0 and 6/1 (S6/0 is the one I wanted to channelize)
GOMPLS(config)#controller T3 ?
<5-5> Controller slot number
I have another DS3 card and it is the only controller that I have an option for. Any help would be much appreciated!
GOMPLS# sho ver
IOS (tm) 7200 Software (C7200-IK9S-M), Version 12.2(15)T17, RELEASE SOFTWARE (fc
1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sat 13-Aug-05 08:20 by kehsiao
Image text-base: 0x60008954, data-base: 0x61DF4000
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT S
OFTWARE
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(5)T1, RELEASE SOFTWARE (fc1
GOMPLS uptime is 17 weeks, 6 days, 18 hours, 11 minutes
System restarted at 16:15:17 DST Wed Jul 2 2008
Running default software
cisco 7206VXR (NPE300) processor (revision B) with 229376K/65536K bytes of memor
y.
Processor board ID 16063557
R7000 CPU at 262Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
6 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 Channelized T3 port(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
GOMPLS#sho run
interface Serial6/0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
dsu bandwidth 44210
framing c-bit
cablelength 10
serial restart_delay 0
interface Serial6/1
ip address 172.x.x.x 255.255.255.252
ip nat inside
ip route-cache flow
no ip route-cache cef
no ip mroute-cache
dsu bandwidth 12288
framing c-bit
cablelength 10
GOMPLS#sho diag
Slot 5:
CT3 single wide Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 17w6d ago
EEPROM contents at hardware discovery:
Hardware revision 1.0 Board revision A0
Serial number 21192556 Part number 73-3037-01
FRU Part Number: PA-MC-T3= (SW)
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 A0 01 00 01 43 5F 6C 49 0B DD 01 00 00 00 00
0x30: 50 00 00 00 00 07 06 00 FF FF FF FF FF FF FF FF
Slot 6:
T3 PA Port adapter, 2 ports
Serial number 10738546 Part number 73-2323-02
FRU Part Number: PA-2T3=
0x20: 01 53 01 00 00 A3 DB 72 49 09 13 02 00 00 00 00
0x30: 50 00 00 00 98 11 06 00 FF FF FF FF FF FF FF FF
1 ACCEPTED SOLUTION
Re: VXR 7206 / PA-2T3
Mark,
Unlike the PA-MC-T3, the PA-2T3 doesn't support Channelized T3.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Mark,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Thanks hritter!
That's what I thought but could not find anything definitive on Cisco's website.
305
