Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
WAAS Tacacs configuration
I have configured tacacs in WAAS devices. after applied the config, i am succesfully able to login via telnet but unable to login GUI.
any guide me to resolve the same
Bronze
Re: WAAS Tacacs configuration
Follow the URL for the configuration of the WAE Device manager using the GUI :
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4013/configuration/guide/device.html
so you lost the acccess after you have enable the tacacs.
I would suggest to diable the tacacs from command promt and then use the above link to configure it properly.
209
