10-07-2009 06:00 AM - edited 03-04-2019 06:17 AM
Greetings:
We have a private WAN IP network (WAN: 10.255.255.0/28) consisting with five different subnets each with their own IP (LAN)addressing space.
LAN 1= 172.16.0.0/16
LAN 2= 10.1.7.0/22
LAN 3= 172.28.130.0/23 (VLAN)
LAN 4= 172.17.0.0/16
LAN 5= 10.169.254.0/24
I need to be able connect LAN 5 to LAN 3 (VLAN) - and route all Internet traffic from LAN 3 (VLAN) to a gateway on LAN 5 - while at the same time restrict LAN 5 from connecting to any of the other LANs.
The biggest problem I can't get my arms around is all of the 10.x networks involved. We also employ EIRGP on each router.
10-07-2009 07:20 AM
Logic check: Will this work?
LAN 5 router:
interface GigabitEthernet0/0
description ***Connection to WAN***
ip address 10.255.255.5 255.255.255.240
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/1
description *** LAN port ***
ip address 10.169.254.69 255.255.255.0
shutdown
duplex auto
speed auto
ON LAN 3 router:
ip dhcp pool JPI
network 172.28.130.0 255.255.254.0
dns-server 10.169.254.10
default-router 172.28.130.1
interface GigabitEthernet0/1.14
description ** LAN 5 **
encapsulation dot1Q 14
ip address 172.28.130.1 255.255.254.0
ip access-group INETLAN5-ONLY in
ip policy route-map INETONLYLAN5
no snmp trap link-status
ip access-list extended INETLAN5-ONLY
permit udp any any eq bootpc
deny ip any 10.1.7.0 0.0.3.255
deny ip any 172.16.0.0 0.15.255.255
deny ip any 192.168.0.0 0.0.255.255
permit icmp any any
permit ip any any
ip access-list extended LAN5-INETONLY-NETS
deny ip 172.28.130.0 0.0.0.255 10.1.7.0 0.0.3.255
deny ip 172.28.130.0 0.0.0.255 172.16.0.0 0.15.255.255
deny ip 172.28.130.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 172.28.130.0 0.0.15.255 any
deny ip any any
route-map INETONLYLAN5 permit 10
match ip address LAN5-INETONLY-NETS
set ip next-hop 10.255.255.5
10-07-2009 12:41 PM
shutdown < --- Your LAN may NOT work.
10-08-2009 03:59 AM
Yes - I had that down prior to shipping the router to LAN5. The router is now up with LAN up, but neither LAN on both ends can see the other. I can ping hosts on LAN3 from the LAN5 router, but hosts behind each can't get to the other side.
10-08-2009 04:02 AM
Correction - from the router on LAN5 I can ping hosts behind LAN3 router - but I can only ping the LAN port on LAN5 router from the LAN3 router.
