Community Member
WAN Configration
Dear All
Please help me in configuring my Cisco 837 router for ADSL service.
I am finish my CCNA 6days back tried to configure by my self but couldn?t succeed also tried to contact my ISP they say that they don?t support for Cisco might be they don?t know. As my ISP just gave me the WAN connection type Settings here are they
Connection Type: 1483 Bridged Ip LLC
PVC VPI: 0 VCI: 32
Multiplexing: LLC
Qos: UBR
NAT Should Enable
Please help!!
Thank in Advance
Zia Khan
Re: WAN Configration
Hi Zia,
Please find the cisco 800 series router configuration guide. Its has all the neccessary config commands and the example and should help you:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a0080118d1a.html
HTH,Please rate if it does.
-amit singh
Community Member
Zia Khan,
I am attaching a sample config and do the needed changes in IP addressing according to your network and hopefully this should work without any issues.
version 12.3
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname <# HOSTNAME #>
logging buffered 10000 debugging
no logging console
enable secret <##################>
username <##################> password <##################>
clock timezone EST 10
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
bridge irb
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 192.168.1.1 255.255.255.0 (or change accordingly)
ip nat inside
no keepalive
hold-queue 100 out
no shut
interface ATM0
no ip address
no ip directed-broadcast
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
no shut
interface ATM0.1 point-to-point
bridge-group 1
pvc 0/32
ubr ###
encapsulation aal5snap
interface BVI1
ip address XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX *
ip nat outside
ip nat inside source list 11 interface BVI1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX **
no ip http server
no ip http secure-server
bridge 1 protocol ieee
bridge 1 route ip
access-list 11 remark *** Address space for NAT
access-list 11 permit 192.168.1.0 0.0.0.255
line con 0
exec-timeout 5 0
privilege level 15
password 0 <# ACCESS PASSWORD #>
login
line vty 0 4
exec-timeout 5 0
privilege level 15
login
end
* - YOUR WAN ADDRESS
** - NEXT HOP ADDRESS FOR THE DEFAULT GATEWAY
Hope this might help you.
Best Regards
Rajesh
Community Member
Dear Rajesh
Thank for your prompt response. The configuration what your have given to me is with the user name and the password my connection does not required and user name and the password as my ISP says that it?s the DHCP connection it does not require any user name or the password. Please check this configuration which I have tried to configure but it doesn?t work please let me know if any information required .
Router1#sh run
Building configuration...
Current configuration : 2359 bytes
version 12.3
no service pad
hostname Router-1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx.
clock timezone KSA 3
no aaa new-model
ip subnet-zero
ip cef
ip domain name yourdomain.com
ip ips po max-events 100
no ip routing
no crypto isakmp enable
interface Loopback0
ip address 1.6.7.x.x.255.255
interface Ethernet0
no ip address
bridge-group 1
interface ATM0
no ip address
pvc 0/32
bridge-group 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
mtu 1492
ip address 10.201.3.2 255.255.255.252
no ip redirects
no ip unreachables
ip accounting output-packets
ip flow ingress
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer-group 1
router rip
version 2
network 1.0.0.0
network 10.0.0.0
network 192.168.190.0
ip classless
no ip http server
access-list 100 deny tcp any any eq 445
access-list 100 deny udp any any eq 445
access-list 100 deny tcp any any eq 135
access-list 100 deny udp any any eq 135
access-list 100 deny tcp any any eq 137
access-list 100 deny udp any any eq netbios-ns
access-list 100 deny udp any any eq netbios-ss
access-list 100 deny tcp any any eq 139
access-list 100 deny icmp any any
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
password xxx
login
transport input all
scheduler max-task-time 5000
end
BR
Zia Khan
Silver
Try to follow the link from Amit, check the DHCP configuration section and follow the template. It tells how to configure DHCP + ATM connection in the router. It is helpful.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a0080118d1a.html#wp1016512
Hope this helps.
Community Member
The username and password which appears on the sample config is your login credentials and which is not related to the CHAP or PAP.
Try using the above said sample configs and ask your ISP for the Default gareway address. You can use the below DHCP as a sample for configuring the dhcp server.
ip dhcp pool YOURPOOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
Also, is there any reason for using the routing protocal (rip) ????
Rajesh
Community Member
Dear Rajesh
Please help me in solving this problem, if you want I will let you access the router. I tried all my best but couldn?t fix the problem.
BR
Zia Khan
Silver
I found there is no IP at Etherent interface, please assign your private address.
Please try below commands that extract from the sample and fine tuned for your setting.
ip routing
bridge irb
interface Ethernet0
ip address x.x.x.x y.y.y.y
ip nat inside
no bridge-group 1
interface ATM0
no ip address
bundle-enable
no pvc 0/32
no encapsulation aal5snap
pvc 0/32
bridge-group 1
interface BVI1
ip address dhcp client-id Ethernet0 <-- This help to get the IP address from ISP via DHCP
ip nat outside
ip nat inside source list 1 interface BVI1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 BVI1
access-list 1 permit x.x.x.x z.z.z.z <-- your Ethernet segment address
bridge 1 route ip
Please let us know the result and the error message if it fails.
Hope this helps.
You can also try binding the dialer interface to the ATM under the ATM interface config
pppoe-client dial-pool-number 0
Hope this helps
regards
vanesh k
119
