WAN Failover, 2 2811 routers, 2 ISP
newanalyser
Hey guys,
I'm new at this but the company I work for now is asking me to set up a redundant/failover network for them. At the moment we have two (2) 2811 routers and two (2) ISPs. These connect to a 3560 switch before connecting to our domain server. What would be the best protocol to use so that when one ISP goes down, the other will kick in and we'll still be able to access our domain server?
By the way, both ISPs do not use serial interface. They connect directly to the FastEthernet port.
Any help will do.
Thanks.
Hi Ian,
one of the ways could be:
a) EIGRP or OSPF internally to quickly re-route if a 2811 fails or the uplink to one 2811
b) eBGP to the ISP (RAM memory considerations may impose you to have not the full routing table)
c)iBGP in between the 2811s
To this scenario, very easy EEM scripts or object tracking or IP SLA can be applied. I would NOT use HSRP or similar in the core network but this is your choice. Another possibility is with simple static routes but with PBR or changing the longest match (two static routes one less specific than the other one) or even changing administrative distance.
Enhanced object tracking could be quite effective. Much depends anyway on which policies you want to implement on the core network routers (2811s)
Hope this helps
Alessio
pamirian76
well if this is going to be used ONLY for users going on the internet then you don't even need routers.
now assuming you do need 2 routers then I would go like this,
which isp is my mian so one isp will be my main, the one with more bandwidth.
the other is your backup.
so on your main router where the main isp is connected to lets say port 0/0
config t
ip route 0.0.0.0 0.0.0.0 fa0/0
router eigrp 100
network 10.0.0.0
no auto-summary
now I,m assuing you're connecting your stuff together using the 10 subnet.
then you do the same on your backup router except this time
ip route 0.0.0.0 0.0.0.0 fa0/0 200
access-list 99 permit any any
router eigrp 100
network 10.0.0.0
no auto-summary
offset-list 99 out 100 fast 0/1
assuming 0/1 is connected to your switch.
now both your routers are connected into a layer 3 switch.
then on the layer 3 you also have
router eigrp 100
network 10.0.0.0
tried this in gns3 and it works just fine.
gl.
fb_webuser
Level 6
Level 6
From my experience IP SLA is the quickest/easiest thing to do to get it working
Posted by WebUser John Wilson from Cisco Support Community App
Sandeep Choudhary
Hi Wayne,
please look this post .....this is same as urs:
https://supportforums.cisco.com/thread/2040405
