WAN IP PING PROBLEM
Hi , I have a 100 MB Internet customer on EoSDH .
when I ping his directly connetced ip address with me . I get a Latency of 1/2/34 sometimes 1/2/98 and so on my average latency is normal and stable 2 ms, but the max Latency is increasing contionously . Same outputs are coming to ping customer router and if replace router via a laptop with same Wan ip address .Please find the config blew.
CORE#sh run int gigabitEthernet 0/1.100
interface GigabitEthernet0/1.100
description #XXXXXXXXXXXXXXXXXXXXXXXXXX#
bandwidth 102400
encapsulation dot1Q 100
ip address XXX.Y.Z.9 255.255.255.252
no ip proxy-arp
rate-limit input 102400000 19200000 38400000 conform-action transmit exceed-action drop
rate-limit output 102400000 19200000 38400000 conform-action transmit exceed-action drop
no cdp enable
end
SWITCH#interface FastEthernet0/2
description #XXXXXXXXX#290906
switchport access vlan 100
switchport mode access
no ip address
load-interval 30
duplex full
speed 100
spanning-tree bpdufilter enable
end
Connectivity: Customer is connected via our Telco Lines terminating on my switch and after then my router comes .
1 REPLY
Hall of Fame Super Bronze
Re: WAN IP PING PROBLEM
Ramesh,
Based on your configuration, you have a duplex mismatch problem.
G0/1.100 is using auto/auto while the Fa0/2 interface is using 100/FD.
My recommendation is to configure auto/auto at both ends.
Please rate helpful posts.
148
